Topic: wiper motor woes
wakywaco
bullet Topic: wiper motor woes
    Posted: 27 September 2003 at 9:56am
when i turn on my wiper motor, my wires start to smoke at the fuse box. whatthis about.   also, my switch isin the dash and it looks like 2 arrows pointing in each direction. iis this right or is the knob from a hazzard button or something?
wakywaco
bullet Posted: 27 September 2003 at 9:57am
oh   and it pops fuses bad too. ive looked at thjis stufff but see no wires shorting. is this just a bad motor or something
VilleBill
bullet Posted: 27 September 2003 at 11:36am
That should be a 15amp. fuse that also serves the washer and heater. All three systems should be checked for shorts. No way should you be smoking wires before the fuse blows unless the fuse block itself is bad. Check out the back of the fuse block for melting, bent or twisted conections and also for forign objects that may be allowing current to flow through the wires, bypassing the fuse.
It may not be visable. Use a multi-tester.
I had it happen.
Say it's the wiper motor circuit, first check that the wiper linkage isn't binding up and causing the motor to over draw/amp. No? OK next check the motor.
This is done at the motor/wiring connector with jumpers. (if you don't have a manual that tells you how to do this i.m. me) The motors are not serviceable and must be replaced.
bullet Posted: 27 September 2003 at 7:16pm
The original '73 Wiper switch has a green face and has "Wipe Wash" printed on it. It's green because it was illuminated by a remote bulb and fiber optics. It should twist to operate the washers, and pull out for 2 clicks for fast/slow operation
Mine's faded but looks like this:
