Topic: 5-Speed Question
Cable
bullet Topic: 5-Speed Question
    Posted: 23 August 2003 at 8:11pm
Hey guys, I am looking to replace my 200sx tranny after its second rebuild. The 5-speed dogleg tranny's aren't the strongest thing in the world. I keep busting 2nd and 3rd.
Anyway, I am looking for a tranny that doesn't require me to cut a larger hole in my floor. I am also tired of the 1-2 shift with the dogleg tranny. I have heard that some truck 5-speeds have short tailshafts and will bolt up without angling toward the passenger side of the car. Can anyone confirm this?
I can nail 280zx tranny's all day, but would prefer not having to cut up more of my car.
Any help is thanked in advance.
-Cable
-'72 510 2dr
bullet Posted: 23 August 2003 at 9:25pm
I can confirm that NO trucks had the short-tail 5-speed. All the short-tail 5-speeds are doglegs, and were only used in 200SX's and '78-81 510s. Trucks used the long tail trannies starting in 1974.
The truck 5-speed is a standard shift. It's the same tranny as used in the 280Z and early 280ZX, but with different gear ratios.
There were some difference in length of EARLY 5-speeds used in Roadsters and early Z's but they are comp units.
Steve
bullet Posted: 23 August 2003 at 10:34pm
I'd like to have that 1-2 shift--- just to have something different...
guess it gets old after a while? only other type of vehicle I've seen that has a pattern like that was a maserati--- the owner told me its because of autocross racing--- you use 2,3,4, and 5--- never 1-- so they put those gears in the "H"
Currently Datsunless...
'88 Cherokee 4.6L 4x4
'99 Durango 5.2L 4x4
'06 Impala 3.5L
Cable
bullet Posted: 23 August 2003 at 11:04pm
I found some more info on the subject. I guess its a 4x4 tranny with the transfer case removed and a short shaft is used in its place.
That would allow a bolt up without shortening the driveshaft. The question now is which bellhousing to use and what angle the shifter is pointing.
Any ideas?
-Cable
-'72 510 2dr
bullet Posted: 23 August 2003 at 11:47pm
Well, a 1980 tranny will be a L20B pattern and angle. A later truck uses a Z-series engine with the opposite angle offset. Can't switch the bell housing- it's one part with the gearbox case.
As for the length, my info says the extension housing isn't the type that you could put a driveshaft in. And the 4X4 tranny doesn't have a speedometer drive gear.
Cable
bullet Posted: 24 August 2003 at 3:46am
Okay, well I guess the info I have is either incomplete or just dead wrong.
So, let's switch back to my original primary goals.
1) Same shifter location as the "dogleg", no cutting required.
2) Same L-Series shifter angle or really, really close to the L-Series angle (i.e. dogleg tranny)
If I am dreaming about a tranny setup like this, please tell me.
-Cable
-'72 510 2dr
bullet Posted: 24 August 2003 at 2:51pm
The only transmission that has a fairly short shifter location OTHER than the original 4-speed (F4W63) or the Dogleg (FS5W63) is the Nissan competition gearbox. I was told it is shorter than the Z/truck 5-speed transmission (FS5W71C) and was stock equipment in the 2000 Roadster. But all my books say the roadster had the FS5W71A tranny which is just as long as the later Z one. Maybe the shifter is in a different location but I doubt it. I also was told the comp gearbox was a FC5W65 or something close with a removeable bell. But never seen it in print.
I looked at the exploded view drawings of the truck 4WD transmissions and found this out:
Early 4WD 5-speeds are identical to the 2WD. They use a remote T-case with a short stub shaft between them, and the only difference is the 4WD tranny doesn't have a speedometer drive gear. Later ones have the T-case bolted to a completely different extension housing. That uses direct shaft coupling so there's no place to put a driveshaft.
bullet Posted: 24 August 2003 at 2:56pm
Oh, one last thing. The only truck tranny that was 4WD AND angled correctly for a L-series engine is the 1980 one. I can't find a single spec or drawing for that one- my factory 1980 manual doesn't cover 4WD as it was introduced fairly late in the model year. So it is possible that it has the shorter tranny. But I really doubt it; a short tranny is typically also a weaker tranny.
If you do find something that works, and that dogleg is still intact, I'm still looking for one (or 2). I'm sick of the 4-speed in my wagon plus I have a blown synchro in the one in another car.
Cable
bullet Posted: 24 August 2003 at 8:20pm
Thanks for the help.
Where are you located? I am in Hanford, Ca. 93230 (near Fresno).
I would be happy to trade something I might need that you might have. That way no money really has to change hands (except maybe shipping costs).
From the looks of it, I might be going with the 280zx tranny afterall. Is it true that the non-turbo units have a higher (lower number) overdrive gear? I would prefer to lower my freeway RPM and I heard the non-turbo models had lower rear gears to makeup for not having a turbo, then the overdrive was deeper to keep the RPM down for freeway driving.
Is any of this true? Thanks again.
-Cable
-'72 510 2dr
bullet Posted: 25 August 2003 at 8:23am
i have a short 720 5-speed. the speed-o is on the transfer case and the starter is clocked higher on the bellhousing. the beefier 720 crossmember even bolted right in. i have fabbed up motor mounts that split the diff between the lean of the L block and the Z. my truck is a feat of dirty white boy engineering.
bullet Posted: 25 August 2003 at 1:02pm
Yeah, earwig, but that's in a truck! Which used the same tranny model (albiet a 5-speed) to begin with. Or close- is yours the kind that uses a stub shaft between the tranny and transfer case, or the kind where the Xfer case bolts to the end of the tranny?
Cable, I'm up in Tacoma, WA so that probably wouldn't work.
From my info, the turbo has a higher OD than the Non-turbo 'cause it has more power. The turbo 5-speed is a different gearbox, too- a REAL long Borg-Warner T-5 tranny. I have one, was gonna put it in my 4-speed Z but I haven't bought a driveshaft spline sleeve for it (different ouitput shaft on the T-5 vs a Nissan unit).
bullet Posted: 25 August 2003 at 4:07pm
i have the divorced unit with the stubby little drive shaft. the other kind are called married. i don't think much of the T-5 trans. one of my buds has a mustang with it and he's on his 3rd. when he got the car it didn't have 1st. the second trans lost reverse. now the third one won't go into anything. it's only a stock four banger and he doesn't grind the gears or anything stupid like that.
nwdeorg
Admin Group
Admin Group
bullet Posted: 25 August 2003 at 4:16pm
Comp trannys are the same length as all the other Z boxes. They just have the older monkey motion linkage and the three piece cases like the roadster units or the very early Z's.
Randy
Bre620
bullet Posted: 25 August 2003 at 5:08pm
monkey motion linkage...
Comp trannys, I have two, both with bad syncros. I've been told several times that the syncros are NLA for these trannies, or that a guy named Mark bought them all. Also that I'll have to "crack" the case open and count teeth in order to find out which Comp tranny they are. Are these this easy to pull apart and put back together? Also are the gears pressed on and I'll have to take it to a shop to replace the syncros, if a can find them. Maybe I should just sell them. Is there a market for these Comp trannys?
syncros...did I spell that right?
1969 510
1972 510
1969 L521
1979 620 4x4
bullet Posted: 25 August 2003 at 5:09pm
Gee, Randy, and it's a certain Roadster racer we both know that told me the Comp units were shorter than the Standard Z tranny. He showed me the 3-piece case, I couldn't tell if it was longer or shorter than my Z one. Other than the removeable bell and a flanged output shaft, looked near identical to me Z 5-speed. Oh, yeah, had a shifter linkage that looked like the one off a BW T-5 but smaller.
I do know the number on the Nissan units is the length in centimeters, the early Z and late Roadster ones (in my book) say they're 71cm. Same as late Z/early ZX/Trucks after '74. 510, 610, 710, early 200SX, late 510, 63cm. 1200/B210/210 56cm. All Automatics except the early 510 BW units, 71cm. This all bears out- I've had a Z 5-speed, a B210 5-speed, an A10 Automatic, and 2 truck 4-speeds all piled next to each other and the difference was obvious.
But he claimed the Comp box was a 65cm unit. Never heard of or seen such.
