Topic: Best 510 trans
Yellowcar
bullet Topic: Best 510 trans
    Posted: 24 July 2003 at 7:24pm
Can anyone recommend the best trans for a 510 W/L motor?
I heard the 280ZX turbo trans is the one to get but can't remember what year or why it was supposted to be good.
'72 510 LZ2.5
'06 VW Jetta
'98 mercedes C280 sport
'01 ZX9R
'02 ZX6R
bullet Posted: 25 July 2003 at 9:14am
The 280zx turbo uses a Borg Warner T5 transmission. It is aluminum and a bit lighter than a Nissan tranny. It also has a wide gear ratio. 1st gear starts out very low and 5th gear is a high overdrive. The output shaft is unique and requires the matching center driveshaft to be used, not a nissan one.
The best gear ratios overall are the non-turbo 280zx 1981-83. 1st gear is the highest, but 1-4 gears are as much of a "close ratio" as you can get. Due to this higher gear ratio, I would recommend a 4.11 rearend or lower for a 4-cyl and 3.9 or 4.11 for a six.
Also, the later 280zx transmission just seems to shift smoother like a more modern transmission.
Yellowcar
bullet Posted: 25 July 2003 at 1:38pm
Thanks for the info!
The 280ZX trans sounds good, I have an unknown 5 speed trans from japan now (it has 1st gear in the bottom left) but 1st is way too low then there is a huge jump to 2nd.
Because of the motor I don't think I'll have a problem pulling the higher first gear.
any recommendations on who to get a Xmember from and who can shorten the driveline? (seattle area)
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
bullet Posted: 25 July 2003 at 2:50pm
You have a "Dogleg" 5-speed. That's actually the one that fits best; it was the same length as the original 4-speed. Also a bit weaker tranny, though vs the truck and Z Nissan 5-speed (the ZX-Turbo tranny is in a class by itself) Was stock in '77-79 200SX's and '78-81 510s.
But... I'm looking for one, so if you get the ZX tranny in there I'd be interested in buying the dogleg. My Wagon could use the extra gear and I don't want to do any mount mods.
Yellowcar
bullet Posted: 25 July 2003 at 4:14pm
sure, I will eventually get the trans in so I won't need the one I have now.
What area are you in?
Just a question of when I get to it. I am installing new carpet, seats dash, electromotive IGN and some other stuff right now
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
bullet Posted: 25 July 2003 at 4:19pm
I may need some driveline work done this year as well. I'm in the south seattle area, but don't know of a shop right now that I should go to.
The L20b has enough low rpm torque to make up for a small increase in a gear ratio. I wouldn't do that for an L18 though. In my L20b truck, I would take off in 2nd gear all the time with ease. My L18 doesn't like that at all, even though both engines had a Weber and the same gear ratios.
nwdeorg
Admin Group
Admin Group
bullet Posted: 25 July 2003 at 5:07pm
Drivelines Northwest on 4th Ave down by the stadiums will do custom prop shafts and drive shafts, along with u-joints and flanges. I think they will do custom CV shafts as well.
Randy
bullet Posted: 25 July 2003 at 5:09pm
I live near Tacoma.
Yellowcar
bullet Posted: 25 July 2003 at 5:34pm
Well now I have to find a trans
called around but didn't find one so if anyoine is selling one let me know.
The motor iin my car is a 2.5 so torque is really not a problem and the gearing shoud be a good fit (I hope)
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
Guests
bullet Posted: 26 July 2003 at 5:02pm
Well where do you live? If you're on the east coast, you can have mine. I won't ship and you'll have to take it out yourself if you want it. (my car is in body shop restoration limbo and I'm doing the KA swap)
Yellowcar
bullet Posted: 28 July 2003 at 11:51am
I live in the seattle area, thanks for the offer though.
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
bullet Posted: 28 July 2003 at 1:33pm
try car-part.com i just got a T5 for my friends '82 4-banger Mustang. it tells ya what is in junk yards and sometimes the prices too.
