Topic: SR20det into a 521
Roostmonkey
 bullet Topic: SR20det into a 521
    Posted: 31 July 2007 at 7:42am
I'm new to this site, usually I hang at Hybridz.org as I'm into the 240Z's. But ive taken on a project with my 18 yr old son to swap an SR20 into his 72 PU. The motor and disc brake kit's are on order and we.ve begun pulling things off the 521. I havent seen much detail on this swap but I know its been done.Do any of you have info or can you point me in the right direction for info on this swap? I'm a metal fabricator so mounts and brackets wont be an issue but I'm sure theres little tricks that will make the whole job alot easyer. Thanks
 <a href="http://photobucket.com" target="_blank"><img src="http://img.photobucket.com/albums/v650/Boostmonkey/BensTruck001.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
 bullet Posted: 31 July 2007 at 9:55am
Just wanted to say that's a very sweet looking 521!
Which disc option did you get?
Gresham, OR
Roostmonkey
 bullet Posted: 31 July 2007 at 11:11am
I ordered the front and rear brackets from BEEBANI on this site. But after thinking about it more, I'll be wanting to swap out the stock rearend for something with an LSD and most likely wont be able to use the rears. Any recomendations on rearend swaps?
Sorry, couldnt help showing off my Z
 bullet Posted: 31 July 2007 at 11:19am
I'm not much of a Z fan, but that one gave me a pudgy!!!
Fineline had a LSD for sale awhile back...don't know if he still does.  I took apart a hardbody diff and it has the same mounting flanges on the end.  Wrong width, but if you stay with nissan, you may still be able to use the brackets.
Gresham, OR
BEEBANI
 bullet Posted: 31 July 2007 at 6:58pm
Nice looking truck!  You should have your brackets by monday, couldn't remember where you were at?
'76 620
'97 D21 4X4 on 33's
'05 Xterra
airedout
 bullet Posted: 09 August 2007 at 12:03am
All the info you will ever need for this swap you can find here:
Ill either be doing an SR or 350 in my bagged 521 soon!!!
Dwight Fahrenthold
Roostmonkey
 bullet Posted: 13 August 2007 at 3:55pm
Thanks man , that will come in very handy. Hers a pic of the motor. Its on its way from Japan as I post.
Roostmonkey
 bullet Posted: 13 August 2007 at 4:01pm
As you can see, I'm getting a black top, not the red I had ordered. Bonus.
Beebani, I got your bracket's they look good...thanks
datzenmike
 bullet Posted: 13 August 2007 at 8:13pm
[QUOTE=Roostmonkey] But ive taken on a project with my 18 yr old son to swap an SR20 into his 72 PU. The motor and disc brake kit's are on order and we.ve begun pulling things off the 521. I havent seen much detail on this swap but I know its been done.Do any of you have info or can you point me in the right direction for info on this swap?
/QUOTE]
I wonder if it was done in Oz where there's clearance. You are going to have a hard time with that 620 one piece steering column.
Roostmonkey
 bullet Posted: 14 August 2007 at 7:04am
Well, its going into a 521 and I'm sure there will be fitment issues to deal with. I own a metal fab shop so ability and equipment wont be a problem. I'll document the swap and possibly fab extra motor mounts and brackets  and make a kit for sale. Thanks for the heads up on the steering.
 bullet Posted: 14 August 2007 at 1:09pm
Nice car.
I think Z car look best w/o those side skirts but its a nice car
Fineline on here has a LSD
http://www.precisiongear.com/powerbrute.htm
Roostmonkey
 bullet Posted: 14 August 2007 at 8:59pm
thanks....I guess.
71datsuzie521
 bullet Posted: 20 August 2007 at 1:20am
sweet truck, i like th color. i also have a 521. i need to  interior work on mine and im deciding what color i want to paint my truck. im also looking to do a upgraded swap but trying find a simple swap.if you want to look at pics of my truck it in the truck category under updated pics 521.
Mr_Bond
 bullet Posted: 13 September 2007 at 3:36pm
I am puttin my 1969 521 4x4 upforsale. It has a 289 ford v8 with c5 automatic transmission. If anyone is interested or knows anyone interested email me at robinhollandjr@gmail.com and Ill send more info and pictures. Thanks for letting me throw in my two cents
I wake in the morning and piss excellence!
Roostmonkey
 bullet Posted: 15 September 2007 at 9:27am
Its here and its a beauty. Very clean and professionally removed from the donor car.Time to get busy....
Roostmonkey
 bullet Posted: 23 September 2007 at 9:06pm
I'm getting closer to dropping her in and get mount measurements etc...
Roostmonkey
 bullet Posted: 29 September 2007 at 1:53pm
Its in
 bullet Posted: 29 September 2007 at 7:25pm
Seems like there was a big void in the truck arena for a long time, now, all of a sudden...guys are doing all kinds of wild swaps!!  Awesome!  I guess they're coming into their own.  Looking forward to more pics :)
Gresham, OR
madizm620
 bullet Posted: 17 October 2007 at 6:41pm
Hey Roost where did you get your SR from? where ever you got it from looks like they do a very good job pulling the motor and capping everything off, never seen anyone do it that clean before. even came with the driveshaft and motor mounts. How much did it cost?
Lean Green Datsun Machine
Roostmonkey
 bullet Posted: 20 October 2007 at 9:51am
Good eyes Mad, this package was extremely clean and professionally removed from the donor car. Nothing was cut and all the important openings were capped. I got it from a member of Hybridz.org. He goes by " Racer98 " , you can contact him in the group buys forum ( I think). He's more like a broker, you tell him what you want and his contacts in Japan get it, test it ,repace belts,hoses and ship it to him ( in CA ) for his personal inspection before shipping it to you.This proccess took 5 weeks from order to delivery. He's a great guy to do business with, he did everything he said he would and delivered a top quality engine, trans,ecu,harness,drive shaft and downpipe. My cost including shipping was $2600.00. He quoted me a redtop and delivered a blacktop for the same quoted price. I know you can get them cheaper but it can be a crapshoot. I would buy another motor from him in a heartbeat.
