Topic: Fuel Injection
bullet Topic: Fuel Injection
    Posted: 24 December 2002 at 1:38am
when converting over to a custom fuel injection system (l20); say the guts from a Mazda Fe2, (2.2l, n/t.); could I use an aftermarket ignition like an MSD, instead of the mazda's OE ignition system? How could you get away without using any of the Mazda ECU's ignition, sort of a stand alone ignition system that has no ties to the ECU? any ideas?
1973 620 "Prerunner"
L20B,A87,5spd.Lynx,40dcoe,
header,cammed & bored.
zx oil pump,starter,headbolts
& water pump/pulley.
bullet Posted: 24 December 2002 at 5:08pm
Why are you using a Mazda system?
I don't know Mazdas in the least, so I'm assuming this contraption uses a single ECU to control both spark and fuel delivery, which is exactly how modern cars are set up.  Of course, a modern setup needs just about every sensor hooked up or it won't work right.
Personally, I'd use a '80-83 200SX injection system with a custom intake mani if I couldn't find a L-series EFI manifold (VERY hard to come by).  Not hard to make one if you can weld. The Nissan Z-series setup still used separate EFI and EI systems, so I'd just stick with the '79-80 L20B ignition.  The only cross between the 2 systems is the ECU gets its timing from the tach feed (negative wire on primary coil, via resistor).  Much simpler than using a crank position sensor.
If the mazda system is similar than there won't be a problem, just feed the ECU the timing signal from the coil.  If not, there will be a problem of getting all the sensor feeds into it.
bullet Posted: 24 December 2002 at 5:58pm
ok, thanks for the info. the mazda was just an example, just because I happen to know that setup. that answers my questions though!
bullet Posted: 26 December 2002 at 10:15pm
Have you read this on L20b fuel injection?
http://www.dimequarterly.tierranet.com/articles/tech_efi.html
bullet Posted: 26 December 2002 at 11:10pm
Thank you Bleach! Good advice on where to begin.....
