Topic: Icehouse
 bullet Topic: Icehouse
    Posted: 13 October 2006 at 1:05pm
Jeff your boy Shane keeps calling asking for advice then doesnt listen anyways!!!!! Dont give my # out anymore!!!!
He used a wire to hold up the sprocket. I told him to pull the front cover and ck it out or least use a block. Then calls later didnt pull the front cover and says he cant get the sprocket on.
Then he said he has the crank on 10deg adv. I said thats only for the electrcal timming not mechanical timming. Thats has to be on Zero but then he doesnt have the brite links on the chain set up. Cause he has no money for a new chain or at least a new tensioner!!!
But he spent 70 on that stupid dual oil filter that he went searching all over for and spend money on Synthetic on a used motor anyways.
Then I find he gets a motor from Skip which should have the front cover pulled anyways just to see if the tensioner slack side guide is worn ,but now out of money,
70$ oil dual remote oilfilter(really just to look cool)
25 $ Synthtic oil
hey thats a front cover gasket set and a Mr Autoparts.com timming set*Made in Japan)
 bullet Posted: 13 October 2006 at 1:34pm
I like your buddy Shane but seriously he needs to pull the front cover
BEEBANI
 bullet Posted: 13 October 2006 at 4:55pm
Sounds like he needs to pull more than the cover.....Like his head outta his........
'76 620
'97 D21 4X4 on 33's
'05 Xterra
 bullet Posted: 14 October 2006 at 2:41am
haha Yeah he needs to drop off some L motor parts at your house and have you do it I've never done any timing on a L ether, I just pull then and put them in the bushes. I'd rather learn to build a ka or sr.
datzenmike
 bullet Posted: 14 October 2006 at 4:20pm
Hainz doesn't suffer fools lightly.
 bullet Posted: 14 October 2006 at 10:09pm
lol...where's dem bushes located at Jeff? I could use a few L series parts!
 bullet Posted: 24 October 2006 at 3:40pm
jeff Icehouse
Did Shane evr get his motor running?
Did he call you?
never heard back from him ,Wonder if car is in backyard/parking lot? getting ready to get towed!!!!!!!!
 bullet Posted: 25 October 2006 at 10:03am
He told me it was "close" we will see I guess.
 bullet Posted: 25 October 2006 at 10:33am
2 weeks to do a timming chain????????
if he brings the whole motor over Ill do it for free but he better have everything.
and Not a carbon fiber hood that he spent 500$ for and the car still isnt running
 bullet Posted: 25 October 2006 at 3:25pm
He said its back in the engine bay, all he has to do is hook everything back up. You should go help him.
