Topic: Torsion Bar Indexing...
bullet Topic: Torsion Bar Indexing...
    Posted: 02 May 2006 at 4:37pm
So I guess I'll start with why this needs to be done and seeing as how a picture is worth a thousand words....
The first thing to do after jacking up the truck and putting jack stands under it is to mark you arm and frame with a sharpie to let you know your starting point.
Then move the rubber boot back so you can access the c-clip.
Here's a shot of the clip. I was able to get it off with a couple screwdrivers.
Anyone know where I can source these boots new? Mine are dead...
After you pull the c-clip tap the arm back with a hammer until it pops loose. At this point, if your arms are still in good shape you can rotate the arm and reinsert the torsion rod one spline up.
I hate speed mountains
Here's a shot of the whole deal on the floor...
All bent back into shape...gotta love steel
Final clearance. I gained about an inch rotating it one spline. I don't think I'll be ripping that bolt out anymore
All in all it took about 20 minutes and that was mostly cause I used scissor jacks....
dos datsuns
bullet Posted: 03 May 2006 at 1:14am
Looks good Redeye. I did mine after Bleach posted pics of how he did his & yeah only took about 30 minutes. I had 1 of the torsions come out from the arm like your pic shows, the other only the piece that you hammer came off. It's a quick fix for clearence problems for sure. Thanks for the pics.
My 1965 L 320 {all original}
69 L 521 w/KA swap
94 Hardbody [custom]
74 620 project
bullet Posted: 03 May 2006 at 10:04am
just remove the anchor bolts then remove the nut on the A arm up front almost off then pound it out w/o hurting the threads
me and Icehouse did his 521 truck. We NEVER removed the c clip from the back
we just pulled the torsion bar from the front A arm and reindexed it there. Had to jack up the wheel to get it to reinstall. We never wanted to take the c clip out.
bullet Posted: 03 May 2006 at 8:58pm
Yeah after Bleach posted up I had to try it out, I was tired of fixing that in parking lots lol.
The c-clip came off easy. I pretty much pushed it most of the way off with a couple screwdrivers and then popped it out with one of the screwdrivers...It's smaller than the c-clips holding my axle stubs on my jeep. Pulling the shaft was a breeze as well.
Hopefully these pic's will help out the next guy who needs to take care of his torsion arms
dos datsuns
bullet Posted: 04 May 2006 at 12:19am
Redeye, pics really do help alot. Its easy sometimes to "tell" somebody how to do a mod or fix something but with a pic it makes it easier. Thanks again.
69 L 521 w/KA swap
74 620 project
