![]() | Projects North West Datsun Enthusiasts Forum : Member Rides : Projects Topic: Boy am I exhausted.... |
![]() Posted: 15 March 2006 at 9:45pm |
I got some new exhaust on my DD. 1.75" all the way back. L16 intake (port matched) and exhaust... Down tube - torsion bar clearance... this will be reworked for more clearance... Mid-crossmember clearance...Reworking this spot completely as well. |
schnazzy............
I like the way you ran the pipe on top of the 1st crossmember. Ill have to do mine the same way when the time comes.
nice job... you did this yourself?
Driftn620
Enthusiast ![]() Joined: 17 April 2005 Location: Canada Posts: 201 |
nice work... but 1.75? damn ... I can only imagine the pain it's gonna be to redo my 2.5inch exhuast and get it tucked up out of the way
1986 camry - decent stocker driver
1965 F100 - custom, was dads 1973 Yamaha 650 chopper - now a family member 20+ years 1978 620 kingcab - Rally build! |
you should only go 2 1/4" max unless you're working with a v8. otherwise you lose important back pressure.
Wow deletoness.... |
Driftn620
[QUOTE=tdaaj]
you should only go 2 1/4" max unless you're working with a v8. otherwise you lose important back pressure. wow that was a totally blind and false statement but sure what about turbo cars?... high revving s/c cars? that air's gotta get out as fast as it gets in what about V6's? every engine responds differently to exhuast diameter size, even how many bends are in it... and usually I keep quiet about it but I can't any more... back pressure is BAD.. HOWEVER still having some backpressure in the exhuast system is a byproduct of having proper velocity.. this ofcourse only applies for an N/A car ofcourse... Boosted engines basically run as big an exhuast as you can afford (without being stupid) ANYWAYS if space was an issue, and you weren't doing much more then basics on your truck 1.75 is just fine... my comment was mainly aimed at how much of a PITA rerouting my 2.5inch exhuast with how low my trucks being dropped |
Backpressure is bad? you're a fool. How many 4 bangers have you worked on? It's true for turbo cars, but other than that............Enjoy you're 2.0 with a 2.5 in exhaust, and don't say you weren't warned.
Bre620
Enthusiast ![]() ![]() Joined: 04 December 2002 Posts: 676 |
Originally posted by Driftn620
wow that was a totally blind and false statement but sure nice reply...you'll likely just gain noise. Spend the extra $$$ and get a decent muffler. |
If backpressure was wanted then you'd have throttleable exhausts.
The problem with wide-open or overly large exhausts is lack of velocity, which causes a lack if exhaust flow, which in turn causes waste gasses to stay in the cylinders. But too much flow is bad too. Burned valves can happen either way. It's a flow thing, not a pressure thing. Now, on a 2-stroke it's a whole 'nother story. |
My truck uses oil like a two-stroke bitch
Driftn620
Originally posted by Ryan in Seattle
Backpressure is bad? you're a fool. How many 4 bangers have you worked on? It's true for turbo cars, but other than that............Enjoy you're 2.0 with a 2.5 in exhaust, and don't say you weren't warned. how many have I worked on... ummmm how about 14-20 a DAY other factors into exhuast size are the RPM range your engine is being built to run... if I wasn't building the truck to set off above 5K rpm that often, I would go with a 2.25 exhuast, the 2.0 in my 620 pulls all the way to 7K rpm it USES that 2.5 inch exhuast. Make NO mistake I am not some newbie kiddy getting a hard on over 3inch exhuasts with 4+inch tipped Cans on close to bone stock 4bangers. the best exhuast is one that rides the fine balance of velocity and byproduct backpressure, in your desired RPM range. from this you will get your maximum hp gains in the rpm range your using and added throttle response in a properly tuned engine with matched parts |
