![]() | Projects North West Datsun Enthusiasts Forum : Member Rides : Projects Topic: Brake Issues! M/C Upgrade! | of 3 Next >> |
![]() Posted: 06 March 2006 at 2:54pm |
You see this all started the other day when I went out to Pull-a-Part and picked up a e-brake cable for my truck, as it has been broken for many months... I came home and put it in and while I was in there, I adjusted the rear brakes to grab better...I took it around the block and boy howdy, was I impressed what a little adjustment could do....the master was still shot and I had to pump it up several times before it would grab, but it locked up the rear nicely! I headed down to the end of the block and as I approached the turn, pumped the brakes to slow down....ah, hello....NOTHING! No brakes what so ever! I screamed around the corner as I downshifted into second and let the compression slow me down a bit (nice chirp!)...nursed it on home and used my newely installed e-brake to halt me in my driveway! Thank goodness I had just fixed that! By this time it was getting dark and I just said I would deal with it in the morning....The next day I went out there and discovered that the master was empty...filled it up and pumped the brakes and heard a hissing sound of fluid escaping! I crawled under there and looked for a wheel cylinder to be leaking(heaven forbid as I had just replaced all of them with brand new one's a year or so ago!)...nothing! WTF?? I added more fluid to the master and pumped again, standing outside as I did so...It sounded like it was right by the front of the drivers rear wheel...I crawled under just in time to see a drip from the frame...Bingo! Here's the scary part: I SUGGEST EVERY 521 TRUCK OWNER CHECK THEIRS OUT! Now comes the fun part....I decide to replace my master with the dual circuit one that I bought off ebay a few months ago...I rounded out the mounting holes on the master to fit the exsisting bolts: It didn't take much...then I spent over an hour filing the whole in the firewall to get it an 1/8" larger to allow the master to fit flush....finally my buddy came home, and returned my call and I went and picked up his dremmel and it took me less than 2 minutes to finish the job! I mounted up the master and found that it was frozen up! Drats! I told the wife that I needed a new one and went down to AutoZone and forked out 35 bucks for the master and then a few more for new brake lines and some dot 4 synthetic fluid...60 bucks total... So, for about 60 bucks I was able to get a dual circuit master installed and new brake lines all the way to the rear (going down the drivers side of the frame) I just had to take a break and write this up as I have only 1 more line to install before bleeding it and testing it out! (lines are bent already, just didn't want to lay under the truck in the rain!) One thing I found was that I had to reroute the vapor return hose that comes thru wheel well right below the Master just so that the brake lines would have room: Anyways, check your brake lines right on the frame before the drivers tire...there is a rubber isolator there for all 3 lines that caught all the road grime on mine and allowed it to rust....what do you expect after 35 years on the roads? |
dual master?
So what you hook the other line up to? Get a new slave cylinder? Most are Have to order item. |
sorry...dual circuit master....and yes, they had to order it...paid for it at 10 am and had it in by 2pm.... I took out the 4 way splitter that was installed on the passenger firewall and put in a 3 way splitter I picked up at Pull-a-Part...one line to each of the front and the other the input... I ran a new line to the rear along the frame...worked nice...pictures to follow L8r |
All my 521's have the line running down the pass side.
Which m/c did you get? The new m/c was metric wasn't it? The factory 521 lines are SAE.....did you reflare different nuts? How did you get the new hardline into the existing rubber line at the front wheels? |
Gresham, OR |
My rear line also used to go down the passenger side from the 4 way splitter on the firewall...used to...changed that...it was the one that came straight out and then turned and went down...
I put in a 3 way splitter that I found at the Pull-a-part and hooked it all up...no problems on the threading...the master and the splitter were all the Japonese threaded 3/16" lines.....stock lines hooked right up...I haven't finished the rear lines...started pouring rain again and I came inside, then had other things to do... I picked the master out of a 81 280zx just because it was the year I graduated in and it would be easy to remember... |
Thanks for the heads up on the rusting brake lines. When the time comes for me to do the brakes on my 69 Ill look at that area.
hey Pac: My suggestion is do it now...don't wait...the life you save may be your own! If I had just cleaned that area out 8 years ago and then kept an eye on it every time I washed it since, I might not have had a problem with a blown line! I just keep thinking what could have happened when my son has been riding with me!
The '81 Z m/c is biased for disc up front...I'm not sure if it's drum or disc in the rear. I know the '80 is disc/drum.
Looks like someone is ready to put discs up front :) |
Gresham, OR |
after all this was discussed with the wife, she told me to either get it done or get rid of the truck....guess what I told her... "ok, honey...one step at a time!" Mike: I'm really concerned about the SAE/Jap threads issue...the old lines came apart with a LOT of effort...but these new ones went together really easy...I have only to connect the rear line to the flex hose at the rearend but I wanted to wait until I checked to see if I could find a new one as the old one is really cracked....heck, I want to replace all of them with braided stainless! I'll keep ya posted if I find out the answer to that problem. |
oh, and Mike, I just replaced the splitter block and left the front lines alone for now...figured I could do them later...
1979-83 280ZX are all 4-wheel disc brakes. 1970-78 240Z/280Z are front disc, rear drum. |
35buck for a new master is a good price.
Is is really NEW or just Rebuilt. as for the SAE and Metric I notice that on my 521. its different than my 510. The wheel nuts are 7/16 Paul time to get a new Clutch master now to match up with that brake master. As for the wife? Better lay some Alpha man dominace!!!NOW. I would just Yank my crank in front of her and say I DONT NEED YOU!!!!!!!!!!! |
Originally posted by Bleach well it looks like I need a disc rear end then if I'm going to do the disc's up front...gotta use the masters full potential!
1970-78 240Z/280Z are front disc, rear drum. Hainz: It was rebuilt with lifetime warranty...Fenco #M51837 I have a spare clutch master...just don't need it yet! And the wife has actually been after me to get the disc conversion done so she doesn't have to hear about it any more!
Originally posted by 71-521
well it looks like I need a disc rear end then if I'm going to do the disc's up front...gotta use the masters full potential! ...someone just pulled the two rear rotors off the 6-lug Isuzu Trooper at the Tacoma Pull A Part. oh well, maybe next time. |
nah..what I mean is the IRS swap I've been drooling over the last few years...then upgrade that to the 280zx discs... |
Instead of an R160 with trailing a-arms from a 510, why not do the 280ZX rear suspension. it looks almost exactly the same and is an R200 with trailing a-arms (you can get CV joint halfshafts) and already has rear disk.
Sounds good as long as the dimensions are the same...
I messured the wheel base a 521 and a 510, the 521 narrower than a 510 I can't remember if it was drum to drum or tire to tire. Dam now I have to do it again. My consern was getting the 4 lug back to 6 without spacers.
I can't wait to see how the brake upgrade goes. The dual is a lot safer also. |
I had to take the Master Cylinder back in to exchange it today...they used aluminum bleeder valves and when I went to bleed it, one snapped right off! Fricking bummer! I'll use the steel ones off the core before I send it back for my $4.00... Icehouse: the 510 IRS is about 2 inches wider than the truck rear according to the article I posted... at one time you had said you had several rears not being used...want to part with one?
i think hes going to weld them up to make Lockers to drift with.
521 with IRS???? Paul You must be a Engineering genuis!!!!And rich with all these tools your going to be using. |
