![]() | Projects North West Datsun Enthusiasts Forum : Member Rides : Projects Topic: Ryans truck rebuild |
![]() Posted: 23 February 2006 at 9:26am |
I want to see the muffler!!!
The paint on the header looks like it came off. I thoght you painted it? it dont look right. it looks like the stock black with red spots on it or something That header slide past the tortion bar ez?? You got to drive by myhouse It looks good. Now I told you take your time and its EZ. Now your a L series expert. As for the single sidedraft setup U want to get the X over type manifold by Lynx. They are better. I was told. Something to do with impluses |
that makes sense on the crossover manifold. firing order is basically 3,4 then 2,1 so you would have two pulses of intake through one barrel, then it would rest for two pulses and then two more. If 1 and 3 went to the first barrel, and intake ports 2 and 4 to the second then each intake pulse will go back and forth between the two barrels. |
the header did work perfectly. No torsion barf problems at all. the paint did flake off, it's bare metal right now. I'll have to repaint it with what I know works well. The stuff I used this time sucked ballsack. I like the DEI stuff. As for the carby, I agree with the x over style, but I'm bidding on the one on ebay right now. I missed out on my first attempt at getting a sidedraft, but I won't go into that. Oh yeah Hainz, I'm pretty sure that those pistons weren't L18 pistons. oh well, maybe thats better.............. |
what was that paint u used?
I bought some VHT stuff but maybe I should get it prof done ceramic |
Driftn620
Enthusiast ![]() Joined: 17 April 2005 Location: Canada Posts: 201 |
http://www.por15.com/PRODUCTS/PRIMERPAINTSCOATINGS/HITEMPERATURE/tabid/74/Default.aspx
1986 camry - decent stocker driver
1965 F100 - custom, was dads 1973 Yamaha 650 chopper - now a family member 20+ years 1978 620 kingcab - Rally build! |
