Topic: pull over, I can’t hold it anymore.......
 of 6 Next >>
bullet Topic: pull over, I can’t hold it anymore.......
    Posted: 17 December 2005 at 2:55pm
Sorry, I can't hold out anymore. And I still need a straight with cam towers still intact U67 head or maybe an A87 peanut, if I can get away with that. After xmas, though. Anyways it's been bored, tanked, milled just a smidge, and the broken chain guide bolts are out.yes.....
here Hainz, remember these?   ---V
1973 620 "Prerunner"
L20B,A87,5spd.Lynx,40dcoe,
header,cammed & bored.
zx oil pump,starter,headbolts
& water pump/pulley.
bullet Posted: 17 December 2005 at 4:04pm
Nice...those pics look even better on the 'puter screen...
bullet Posted: 17 December 2005 at 7:01pm
a87 closed chamber head, $125
1 jeep
2 troopers
1 chevy
70 chrysler newport 383 power
bullet Posted: 17 December 2005 at 7:02pm
Aren't the intake ports smaller than the u67?
bullet Posted: 17 December 2005 at 9:11pm
Ya I think the A87 ports and valves are smaller, slightly.
So is that block now on your livingroom floor?
bullet Posted: 17 December 2005 at 9:44pm
no i dropped it off up at roys the other night, the close chambered head i have is off another engine
1 jeep
2 troopers
1 chevy
ssfwgn
bullet Posted: 17 December 2005 at 11:10pm
are you going for a pump gas motor?
bullet Posted: 18 December 2005 at 12:35am
yes, definately
bullet Posted: 18 December 2005 at 12:38am
Should have gone with the stock dished pistons and an A87 closed chambered head.
ok, scrap that block. Just buy a KA24DE
bullet Posted: 18 December 2005 at 12:39am
should've
bullet Posted: 18 December 2005 at 8:51am
Ryan ,why didnt you have Terri assemble the whole bottom end? I think it would have been better it he did that. Gap rings ect.... ARP bolts
The A 87 if closed chamber has smaller intake ports which can be enlarged if you PAY for it. Just be careful not to get into the water jacket. Other wise it does have the 1.65 intake valves as the U67.
also I have the 1/8 BSP adapter for the block if you want to go to a mechanical oil gauge. Dont use the ones in the store they are close but not the correct thread.
also you can get new Dip stick gauge from nissanparts.cc fro like 3$
If you need help timming and chaining that up let me know. Im busy with work but if its allset(nice clean and all parts there) up it will only take a couple minutes to do.
PS make sure that front cover where the inside of the water pump is good or maybe coat it. Unlike mine! water in the oil pan!!!! But hell the motor looked good from the outside
I thought those were L20 pistons he bought on the ebay site. Those were deep dish if I remeber right but said L18 85mm.
bullet Posted: 18 December 2005 at 11:25am
No, Ibought l18 pistons. and terry did gap the rings, I can slide them in and assemble the crank myself, that's not hard. as far as the timing, I've got it now, and the front cover's not going on this time until it is timed. I've spent way too much already to do something wrong now. I still have to take the crank and have it micropolished first, then find new standard size main bearings.
bullet Posted: 18 December 2005 at 12:55pm
I bought some bearings thru Mr auto-parts.com also got he OS Giken timming set(l20)
But most stores will have these bearings or get them from various manufactures
Rock auto
importedcarparts ect......
got photos of these HIPO made in Taiwan pistons?
or you gret hose Sealed Power L18 pistons again
bullet Posted: 18 December 2005 at 1:29pm
those sealed power pistons were a crappy design, these pistons are much betta. I'm actually getting the main bearings that are listed in the nismo comp catalog, as well as the high volume pump. autosport gets that sh it for about half the nissan cost. for instance, the pump lists through nissan at 101.00, he told me 56.00 for the same part #. same with the bearings, and the high strength head bolts.  I'm not cutting corners this time, at all. I've already thrown out my lash pads, oil pump, water pump, head bolts, main bearings. that way the temptation isn't there to slap it together. feel me?
bullet Posted: 18 December 2005 at 1:55pm
thats a good way to go.
1 jeep
2 troopers
1 chevy
bullet Posted: 18 December 2005 at 1:56pm
what do you have for u67 heads, Ted??????????????????
bullet Posted: 18 December 2005 at 3:13pm
56$ sounds like a stock pump to me. They got to add there profit margin in there.(autosport)
x ref the #s. from a true turbo pump to a stock pump.
say 280z to a 280zx turbo. If its one # then its just a standard pump you got.
if true then I got to get one also.
But remember I found many a store list the 510 clutch as the same as a Roadster. But find out its just a 510 clutch. the stock 350KG model
As for the Sealed Power pistons. Well (Sterling) makes alot of pistons for the V8 crowd. Cant see how they can go bad.
PS Autosport sold another kid I know a Cam. I found out later it was just a Delta Cam. That means the lift isnt as advertised. I got them for 33 $ w core exchange from Delta. meaning whats the mark up. So what is their cost of a TURBO PUMP?
Mr auto-parts.com list the stock oil pimps for both cars but doesn not list a turbo so will assume its a stock pump 41$
Rockauto does list 2 oil pumps one for a stock L28 which should be the same as for the 4 cyl vehicles and the L28 turbo which has another part # Beck Arnley Brand and Sealed Power(repackaged Jap part). and its close to 85-100$ for the pumps.
So I figure Autosport with their profit margin(mark up gave you a stock pump. Catch him in a LIE!!!!!!!!
bullet Posted: 18 December 2005 at 3:14pm
Ted or Doug, we should see if the 280ZX in the Tacoma yard has a 5-speed in it. Now is the time for Ryan to put a 5-speed in. Also need a front driveshaft from a 1974 1/2 to '79 truck.
I'm sure this L20b will be great but there's no need for more over revvin on the freeway. That 5th gear will help prolong the life the engine for muddin' and sand dunein'
bullet Posted: 18 December 2005 at 3:39pm
bullet Posted: 18 December 2005 at 3:58pm
yeah I see its a 101$ unit from nissan. I have the # in my book
But I still think its a stock pump they superceded the # to the stock one.
But I will go down there if I dont work over X mas and ck that out. If true I will get one myself.
I had Brad at Autosport get me some 240z pistons found out later made in taiwan. I said NO Taiwan. Then I found out Silvolite is cheaper and made here in the states . He should know where to get this!!!!Said cant find a supplier. Now w the internet there is no excuse.
I myself think stock pumps are fine on a 4 cly cause they used the same pump on a 6 and your not going thru another journal or whatever. But on the higher lift cams I maybe say get them or if running a spray bar get the Turbo pump.
