![]() | Projects North West Datsun Enthusiasts Forum : Member Rides : Projects Topic: My 74 620 project!! | of 19 Next >> |
![]() Posted: 16 November 2005 at 9:04am |
Well after about a month of waiting & with the help of my friend we picked up a 74 620 from Steroid yesterday. Mike gave me a price i couldnt pass up
![]() Mike himself directing traffic... ![]() al loaded up... ![]() the colorado river behind us, Nevada on the other side, at the end of Mikes street... ![]() |
Yay! looks good man. An hour with Mike is not nearly enough time to hear one of his stories! body drop this one? |
Body drop probably not but i will be doing an air bag suspension sometime down the line. Later today ill get a few more pics.
steroid
Enthusiast ![]() ![]() Joined: 10 January 2003 Location: United States Posts: 749 |
Just a reminder, the 2 trucks that are in the background of the top photo are still available...... I know, Iknow "Just leave a message, maybe I'll call" (Joe Walsh)
PS Yes, that's the (red roof) fourdoor's cab above Mark's new truck in the background. Getting closer hopefully. ![]() |
Mike
Well today i tore into the 620 & got a few things started. I removed the seats & cleaned the cab floor & dash, it was really dusty!
![]() heres the roof i may use later on if i do a convertable or chop top... ![]() replacement core support. check out the pass. side body mount, its broke off from the frame.. ![]() ![]() the 'sunroof' that will be gone eventually.. ![]() the sway bar & ladder bars.. ![]() I also checked the fluids, oil is clean & full, radiator is dry, brake master is full, clutch master is empty. I gotta give Mike a big thanx for all his generousity & help with this project. And hey, somebody buy those other 2 620's soon!! & a few extra parts Mike gave me, what is the black roundish part called? ![]() |
steroid
Hi Mark,
That part is up inside the fuel filler area on the passenger's side wheelwell. It is the "chamber" that would catch fuel sloshing through the vent tubes from the gas tank. There should be a stock one on that truck, up above the fuel filler hose. This one came off of one of My trailers made from a 620 bed. I just threw it in there the other day, but it might come in handy someday. See guys, how rustfree these Arizona truck cab floors are?!? The blue roof that I threw in belonged to a cab that I was forced to cut up and it's floor was almost as rustfree as this one!!! I got 2 more rustfree trucks available!!! Don't delay-call today, operators are standing by!!! Good luck Mark, and thank You. By the way, if it is being thrown out, please save the sunroof for Me. I'll put it in the vintage "museum"!!! |
Mike
I like the canopy...is that straps holding it down?
Thanx, the shell will be gotten rid of as soon as i clear more room in the yard for the stuff thats inside the bed now. We had to strap it down so it wouldnt blow away, we encountered 60 mph wind gusts crossing the Mojave desert!! Mike, the sunroof is yours.
Man that floor is pristine... Wish mine was like that |
Update, ive been trying to get it to fire up but ive discovered that the starter will need to be replaced. I dont have the key so i hooked up a tempoary ignition switch with no luck, i can hear the solenoid "click" & thats it. I have found starters at Kragen for about $46 for the stock one. Bleach also told me about getting a gear reduction starter off a Z car, it has more tourque.
Ryan just got a brand new one of those before his motor pooed...worked very nice |
Ill price the Z starter but most likely Ill get the stock one this weekend due to $ issues. I did get a little done yesterday, i took the traction bars off which will be returned back to Steroid & i also took 3 leafs off of each side just to lower it a bit. Check out the differential, at one time it was a chrome moon hub cap! I guess back in the day it was common for the 620 guys to run these as a dress up for the axle, its held on with long springs.
![]() ![]() ![]() & a shot of the L 18 after the 1st cleaning,,,, ![]() |
BEEBANI
Enthusiast ![]() ![]() Joined: 22 July 2005 Location: United States Posts: 792 |
Ahhh, takes me back to when I first rolled my '75 home. My frame has been at the powdercoater's for too damn long! Of course they're fast when they are doing parts for my work, but when it's something for me, they take forever! No biggie, seeing as how I have nothing ready to bolt up to it, gonna try to paint some things today. Looks good Mark, let me know if you need any help puttin' that thing in the weeds! P.S., you Cali boys are lucky, sunshine in the winter time, it is impossible to get anything done on these trucks when you have to contend with an Oregon winter! |
Thanx B, i wish i had the time & $ to do a frame off job but this will be my new daily & need it running quick. I bought a new starter today {$36}& its turning over nicely now but i wasnt getting any fuel to the carb. so i guess its time for a new fuel pump. Im also going to use my test light & check the coil, condensor,etc... Eventually Im going to build a 2 link w/ a bar going inbetween for the rear & for the front im hoping i can install the bags without notching the frame. I will probably turning to you for help/advice when the time comes. And yes our "winters" consist of 65 degree's in the day!
when you get a new fuel pump, try to find the flat top style and not the kind with the two towers like you have now. those gear reduction starters are the way to go. they're around $80 at Napa Auto but well worth it for the performance and durability gain. i wouldn't want to go back to a regular one anyway. that baby moon hub cap is a pretty good/ funny idea. i kind of wanna build some ladder bars or traction bars like those ones some time. i get a lot of wheel hop when i'm wheeling in the sand.
You might want to consult with Bleach as to what happens when you take off that many leafs since you intend on making that a daily driver... Especially since by the looks of it you've left only the main leaf which unfortunately on that setup isn't the strong type, and the overload which won't help avoid what Bleach had happen to his since it isn't clamped. Kinda weird, how that's a '74 but doesn't have the stong leaf setup. Really should keep at least 2 clamped leaves unless you put the traction bars back on. SOMETHING to keep the axle centered.
Im trying to figure out that fuel pump situation on this truck
I see the clip where the filter should go and where the line should come from. Look like from the other side underneath.??? |
My springs were bent when I got the truck. Removing all the other leaves showed it even more. My truck was lower on one side even when the suspension was stock. When I started to notice the bend getting worse, I replaced the leaf springs. As of now, I run one main leaf from a 3-spring set and the longest support spring from a 5-pack of leaves. It rides even now. |
I think the fuel filter and line is just flopped up over the valve cover. The pump outlet is going to the fuel rail, the inlet is coming from the filter but the filter inlet looks like it's hooked up to the carb from that angle. I'm ASSUMING the line is just disconnected, and the carb is actually hooked up to the rail. The fuel return line is plugged off- that's an L20B fuel rail, BTW. '74 620s won't have that return line.
Bleach- that's what I meant. The main spring, when no additional leaves are used, twists far too easily. You need the second leaf to reduce the amount of twist to add rigidity since there is no other method of centering/unswaying the axle. I'm not saying that removing SOME leaves will cause the spring to twist, just adding the second leaf alone nearly doubles the ability to resist twisting. But the overload does not do anything for twist since it isn't clamped to the main. |
Yeah sorry for the confusion, when i took the old starter out i just flipped the filter over the valve cover for more room. As for th efuel pump, did datsun make several different kinds that all swap or is the one Earwig mentioned a special one? Ill follow the advice you guys give on that area. I dont like replacing parts every year. And it looks like ill be using a replacement ignition because it'll cost me $55 to have a key made!! No way im going to pay that much, it cost less to rent the tow dolly
