Topic: Waahoo
SquirtB
bullet Topic: Waahoo
    Posted: 07 September 2005 at 12:08am
Well i finally put some air bags in the rear of my truck,i got to the shop at 8:30 and got outa there around 3ish.I had to ditch the exaust from the muffler back(i already miss the tips),re-route some brake lines made a bridge from frame rail to frame rail for the upper mounts and used some air ride s-10 lower mounts,unfortunatly i did have to cut 6 very small(just big enough for a socket) acsess holes in the bed.Seems to have worked out well.I sorta got lazy and left the shocks for tomorrow,man what a mistake its very bouncy-in fact i can bounce the back by hand and the tires lift enough to move it side to side.It seems i little lower with the bags compared to the air shocks but the nicest thing is now im running 40 psi in the rear compared to 140-160 with the air shocks which was probally hard on my compressor.I think once i get the shocks in where i want'em it should stiffin things up abit(i hope).
dat 620
madizm620
bullet Posted: 07 September 2005 at 10:42pm
that dope Nathan, you'll have to drop by sometime i wanna check it out. So what you want for your shocks? . I got the motor in and almost ready to fire, just need to put the starter bolts in and some rad fluid but i been to lazy cause i been work 14 hour days at work.
Lean Green Datsun Machine
SquirtB
bullet Posted: 09 September 2005 at 12:06am
Yes ill definatly pop in mabye next weekend,i got the shocks in but lost 1/4 inch of drop(they were binding)-so re did them today and everything works great.I guess the true test will be Vans. crappy roads and the autoX saturday if i get in.Oh and the air shocks are free-2 used and 1 new, you can even have all my old air lines I ran all new stuff for the bags.
dat 620
layinga521
bullet Posted: 09 September 2005 at 11:39pm
PICS PICS PICS PICS?!?!?
bullet Posted: 30 September 2005 at 6:42pm
Ya what he said...
