![]() | Projects North West Datsun Enthusiasts Forum : Member Rides : Projects Topic: My long travel |
![]() Posted: 17 July 2005 at 6:12pm |
OK, time to begin this thread. So, I've done alot of thinking on setting up a long travel for my 73. I hate torsion bars and the stock susp. for off road. It just doesn't work. I as of today went to a pull a part to do some measuring and research. I had alot of good luck. Originally the idea was ford ranger or bronco I beam susp. not gonna work. way too much fabbing and aside from that, the beams are different lengths. I did discover however that the ford f100, and I believe it to be 1974, had a similar I beam setup, except the mounts for the beams and control rods are directly to the frame. the rangers susp mounts were built into two crossmembers. The cool thing is, I should be able to unbolt the spindle, beam and control arm assembly, and weld it directly to the frame of the datsun. looks like it would work. that also gives me a chance to use the 10 or 11" front disc brake spindles from the same truck. total cost? beams - 21.50 ea, spindles 11.50 ea. , and control arms 11.50 each. Then i would have to find adjustable linkage for the steering from a mid 80's toyota truck. I think. whats left to actually fabricate? upper coilover mounts. other than that, I believe it would be fairly simple, but it would still give me the much longer travel, much wider wheelbase, (approx five feet!) that's almost a a foot wider, (or 6" on each side). Not to mention fatty disc brakes. so, I think I'm gonna buy the beams and control arms to start with. then go from there. how about that? Here's a picture of a truck with long travel front, notice that it 's much wider than the rear. I do however like the sound of using a rear out of a toyota, who told me about that? I measured the rear on an 85 today , it was almost 5' across, so that would give a little width in the rear. Either way, thanks for reading my short little novel here. Let me know if you guys have any ideas or info on the f100 front brakes, or whatever. |
oh great! so you're going to buy that Toyota? |
I think it was GarryK6 who mentioned the Toyota rear. The 2wd rear axle is a 5 on 4.5" bolt pattern, this matches the Bronco II and Ranger stuff. So...I take it this isn't your DD |
not so much. but the rear will come later.
So...all this begs the questions... Should have the new rearend in it next weekend. All locked up and ready to go... That's the cars co-owner/co-thrasher with the stupid grin on his face... Sorry for the hi-jack, but nobody else I know has a fire road flogger... |
And if it's gonna be a little while before you get parts, I 'should' have a clear driveway to the garage sometime this summer...
Is that an offer? Not too many good places to off road close by. and your pic didn't show up.
garryk6
Enthusiast ![]() Joined: 04 December 2004 Posts: 338 |
Ryan, I have just the ticket for you! The Toyota 2wd rear I have, that came out of a 620 4x4, had 5 on 4 1/2" to 5 on 5 1/2' adapters to match the lug pattern of the Jeep Narrow track Dana-30 front end. So that will match the Ford F-100 bolt pattern. Also, I have a set of 15x10" white spoke rims with some decent 31x10.50 tires for the same 5 on 5 1/2" bolt pattern. The Toyota 8" rear end is easy to find 4.88 and even 5.38 gears as it is the same as the 4x4 rear. I'll let you have the rear-end, the wheel adapters, and the set of white spokes and tires for a mere $100. Hope this helps your decision out! Garry K in Port Orchard, WA
1966 L520 J-13ss Daily Driver
1964 NL320 Project Monster Datsun 35" mudders 1963 NL320 Restoration Proj 1948 Chevy PU Restored 1932 Ford model B PU project 1948 Allis Chalmers G tractor |
so, how wide is it? and I assume it would basically be a bolt in swap? thanks Garry. Do you know what gears are in it? Is it locked at all?
garryk6
Ryan, Unfortunately I had ground the old spring perches off to put the axle on my monster scout, but it will be reall easiy to weld a new pair of mounts on there for your 620, and you could do a "spring-over" while you at it, to put the axle under the springs to give you about a 3" rear lift. I will have to run over to my dads to measure it,as I ran out of room, and took it to his barn to keep it out of the weather.. Talk to you later, Garry |
Pic should work now. I'm teaching myself how to run a server and I somehow lost my ftp address.... Yeah that would be an offer, I like making stuff do stuff it's not supposed to do. There are a couple of jumps in Seattle, if you don't mind on-road stuff |
deleted
garryk6
Then You can just put the axle back on top of the springs as before. It is a little wider than the stock Datsun, but will look good with the wider tires and the front suspension. Garry K in Port Orchard.WA |
garryk6
Ryan, 56" drum face to drum face. That does not account for the wheel adapters which will add an additional inch each side to use the 5 on 5.5" wheels. The Toy guys are using the Toyota 8" rear behind Chevy V-8's and not breaking them!! That is whay I was going to use it on my project, but ended up with a matched pair of Chevy full size axles instead... Garry |
Ok, thanks Garry, but I'm gonna tackle my front susp. first. But yeah, it sounds like a good swap, especially with the avail. of lsd's and gears.
garryk6
Just let me know, and I'll save the 15x10's and the 31x10.50's for you too. I'll just put them all over at my dads place so I have some room to work. Talk to you later, Garry K |
madizm620
Enthusiast ![]() ![]() Joined: 24 February 2003 Location: Canada Posts: 440 |
![]() Lean Green Datsun Machine |
That ought to give Ryan a pudgy!!!
Gresham, OR |
hey cool! oh wait, I have those pics. in fact, I got them from Bleach about a year ago. I emailed the guy and chatted with him for awhile about what he did. I have this datsun, too, but he has stock front susp, except for the real long shocks....
Do you have anymore shots of the white one? Specifically a close up of the control arms? |
