Topic: so it end eth?
bullet Topic: so it end eth?
    Posted: 05 February 2005 at 9:25am
presumably, that is. I'm heading over to Bleachs' house in about an hour to hopefully insert my 20. all I ask for is good luck. I've never built or installed a complete engine before. I hope I make it home. Ready Bleach?!?!?!?!?!?!
1973 620 "Prerunner"
L20B,A87,5spd.Lynx,40dcoe,
header,cammed & bored.
zx oil pump,starter,headbolts
& water pump/pulley.
bullet Posted: 06 February 2005 at 10:53am
well, Bleach and I took the truck down to have it dyno'd last night around 11:30pm, turns out this bad ass little puppy is pushing close to 330 hp, amazing.
bullet Posted: 06 February 2005 at 11:35am
bullet Posted: 07 February 2005 at 12:58am
Wait till Bleach tells Ya the story about this engine change!
here a radiator. always use a new one at this price(3 core)
get new carb weber DGV also.
Like I said before always take your time building a motor. Never Rush! Being cheap and in a hurry killed this project.
http://www.rockauto.com/ref/SPI/Radiators/RadDetailCU638.htm
Ryan hope you make it home.
You might be needeing that L16 again!
get the running lights working correctly again.
That truck would be a cool hunting rig
bullet Posted: 08 February 2005 at 11:14am
Bleach,
I dont think well be hearing from Ryan!anytime soon.
He think his rig is complete.
Then when it breaks hell be back!!!!!!!!
Radiator spring s a leak
or timming set falls OFF
bullet Posted: 13 February 2005 at 9:40pm
Or my server has been down for the last week. I just got back from Leavenworth this weekend. This week has been interesting, though. First off, I would like to say thank you to Bleach for going out of his way last weekend to help me. I also nned to thank Hainz for his generousity and for lending a hand. Without your guys' help, I'd still be stranded. These two guys went way out of their way to help me, and show me how things shoulda been done. I was in hurry getting that engine together, and tried to cut a few corners. Without going into too much detail, I'm happy with how my truck is running, (now). I had to rep[lace the throttle cable, rejet the weber, and tighten a few things, but after all is said and done, there aren't any wierd noises, no leaks, the engine actually runs colder than the l16, and I makea lot of usable power.
So, thanks to two great Datsun guys, Bleach and Hainz, I owe you both. And Hainz, my truck will never be finished...........And guys, do it right the first time. Luckily, I had good help. Next time I may not be so lucky..........................thanks.
bullet Posted: 13 February 2005 at 10:42pm
well about time you wote back
Well get another car as a spare.Then maybe we can do this motor right the next time.
So start saving your money. Causse that motor will not last forever. If it does, only cause I tried to get that slack side guide the best arch I could to keep the chain tite. But thats alot force on one little bolt with the lower one broken. Also the lower bolt broken on the tite side.
Ps I should have charged you 40$ for the Roadster clutch
5 $ for the oil
2.50 for the side gaskets
1$ for the Go faster oil filter.
You get your running light to work correctly?
Hows the Roadster clutch?
Might not be good for everyday driving but they work GOOD!!!!!!!!Stiff!!!!!!!!!!
bullet Posted: 13 February 2005 at 11:28pm
I traced the wire for the running lights and found it had been cut, no problem, easy fix. The clutch is awesome, i owe you for that. Not so bad in busy traffic.
bullet Posted: 14 February 2005 at 8:30am
Also fix the valve cover hole you put in the back hitting the water line. I would thread it for a plug and JB weld it. The thread the reg holes unstead of using sheet metals screw(looks half assed).
Impertedcarparts.com has KYB Gas a Just shocks also. That would stiffen up the rig. Maybe even raise it up abit. Thse shocks on there are shot!
bullet Posted: 14 February 2005 at 11:43am
well I'm glad it's still running and hasn't thrown the chain!
Keep those revs below 5 grand...
bullet Posted: 14 February 2005 at 7:34pm
I'm going to buy ranch shocks, they make a replacement up[grade for the 620.
bullet Posted: 15 February 2005 at 12:12am
YOu mean Rancho shocks?6200series
Test them next time at a 4x4 place then ck out some KYB Gas A Just. There is a differnce.
I think the Gas a Just would be better if Importedcarparts does really sell them.
