Topic: rear disk brakes
Drewman620
bullet Topic: rear disk brakes
    Posted: 14 January 2005 at 9:44am
Hello again,
 I wanted to convert the rear the disk brakes and wanted to know if you guy had any info?  Is this a common conversion? I have searched the forum and did not really find anything that would help me. Can I put another make (Nissan Toyota) of rear axle that has disk brakes already on the truck? if so what axles fit the 620??
Thank you for your time
Drew
bullet Posted: 14 January 2005 at 9:58am
As for width, only the 620 and 720 trucks are the same axel size. The trucks didn't have rear discs untill the full size Titan. (unless maybe some 4x4 Frontiers have them)
Anyway, you'll need to swap discs onto your truck. There is no easy axel swap.
http://www.birfield.com/~morgan/tech/rdb/index.html
This page gives you some ideas on what you can do. You'll end up with a rear rotor that is quite a bit larger diameter than the front if you do this.
Drewman620
bullet Posted: 14 January 2005 at 10:10am
thank you bleach for the info, I was hoping it was a easy axle swap thank you again
bullet Posted: 14 January 2005 at 10:29am
No problem Drew. Don't be stranger! Post often....
bullet Posted: 15 January 2005 at 8:00am
actually bleach, some of the pathfinders in the hard body, had disc brakes. but they didn't use leaf springs for the suspension. they had a 4 link with coils. isuzu had disc brakes on the 89 and up rodeos, trooper 2, honda passports and some amigos. they used the conventional leaf spring in the rear. and are almost the same width. might have to relocate the spring pearches.
1 jeep
2 troopers
1 chevy
70 chrysler newport 383 power
Guests
bullet Posted: 15 January 2005 at 5:48pm
what about the 9 " Ford w discs from Lincoln Versailles.I do not know about Datsuns,but before my King Cab,i used to own a 1973 Ford Maverick.I swapped front Disc spindles(easy) from a 1975 model,and for the rear i swapped the Versailles rear,(Bolt on and easy).Gotta love Ford
bullet Posted: 16 January 2005 at 12:16pm
yeah but finding one of those lincolns isn't always easy. i know of where there is 2 of them but... they also are a 5 bolt pattern tyoo so using a 6 bolt front wheel and a 5 bolt rear wheel would look funky. these other sources are a little more plentiful. oh and as i went to a wrecking yard yesterday i found that some of the isuzu trucks had a rear disc axle also.
1 jeep
2 troopers
1 chevy
Drewman620
bullet Posted: 16 January 2005 at 2:41pm
thank you guys for all the help and info
lowpsi
bullet Posted: 19 January 2005 at 9:44pm
As for the path finders and the other 6 lugs you spoke of
any idea how CLOSE they are to being the same measurement ?
with a 4 link on mine the perch tabs are open to change
but the gearing might be better too for the highwayy>?
thanks
Dragging thru life
bullet Posted: 19 January 2005 at 11:30pm
i know the isuzus came with 4.37's and 4.77's i think.
1 jeep
2 troopers
1 chevy
bullet Posted: 20 January 2005 at 12:16am
I think the Pathfinder had 4.11 gears. Nissan4wheelers.com forum would know.
