![]() | 510 North West Datsun Enthusiasts Forum : Datsun : 510 Topic: backfire? O_o | of 2 Next >> |
anubis_4_99
Enthusiast ![]() ![]() Joined: 22 April 2004 Location: United States Posts: 346 |
![]() Posted: 02 September 2004 at 9:22pm |
all of a sudden i'm backfireing while in gear and decellerateing, and have lost alot of power while driveing, i've got less then half my boost, and all my plugs were charcol black, one even felt rough to the touch like crap had been melted onto it, any idea's guy's? i dont have to drive it for a few day's so i have a little bit to figure it out and if it's safe enough to drive without hurtin anything
defdes
Enthusiast ![]() Joined: 17 May 2003 Location: United States Posts: 849 |
Sounds like your running too rich....was that too obvious an answer? Sorry.
'72 LZ22 510
'71 L16 510 Vintage CS Racer |
anubis_4_99
i thought about that too but i adjusted the carb and still had the same problem?
defdes
Any black smoke out the pipe? or smells?
'72 LZ22 510
anubis_4_99
nope, nothing that i've noticed
defdes
Wow, this is almost like I.M., I dunno then, sounds like you need super-tech advice which I am not.
'72 LZ22 510
anubis_4_99
Maybe ck the timming again , distributor loose
Still running points-condensor(new ones)? Get a electric ignition if you dont have one already. I dont know unless a main jet got loose in a carb but highly dought it |
anubis_4_99
fixed it, dont know what i did to do it tho... oh well, at least it's fixed
anubis_4_99
guess it's not fixed.. it only seem's to be in the higer rpm's though, could incresed backpressure do that? im also loosing 3/4's of my boost as well
ZEED
Novice ![]() Joined: 24 January 2004 Location: United States Posts: 33 |
maybe an exhaust leak before the turbo, will cause a loss of boost and a decell backfire , with a carb the fuel mixt can be very rich on decell , air will enter the exhaust through the leak and the mixture in the exhaust ignites causing a backfire.
79 620 WITH 83 280Zx TURBO ENGINE,TRANS, INDEPENDENT REAR END,280Z 4-BOLT FRONT HUBS WITH 300ZX ROTORS & 88 TOYOTA 4X4 TRUCK CALIPERS,18INCH WHEELS, DOING BODYWORK NOW.
anubis_4_99
k, i'll check that tomorrow, thx
74wagon710
Check your coil. sounds like you have a weak one. Under boost the plugs need plenty of voltage to jump the gap especially under boost.
anubis_4_99
could my turbo going out cause these kind of problem's? i'm getting 1PSI of boost now but i dont seem to have lost any more power then before (im going to replace most of the electrical stuff soon because after i come to a stop, i try to go again and i have to rev it a few time's before the idle straighten's out enough for me to take off, wont be driveing it too much anymore untill i get this figured out)
808DA6
Enthusiast ![]() ![]() Joined: 12 August 2004 Location: United States Posts: 243 |
What kinda carbs are you running? It sounds like you're describing the same type of prob my friend is having with his SU's. When was the last rebuild on your carbs? Dual-sides or single-up? ~B |
anubis_4_99
have no clue the last time it was rebuilt, running a single weber
but i dont think it has anything to do with my carb, my car run's perfectly, i barely get any backfire anymore except at high RPM's, and now im getting spuratic boost pressure, i'll have 1 PSI one minute, then 5 minute's later i romp on it again and i'll have my full 12 PSI |
May be the turbo, dude.
anubis_4_99
that's what im thinking, i just dont want to have to shell out for a new one
take your chance at a junkyard, find out what kind you've got. t3 probly.
anubis_4_99
it's an old rayjay out of a VW bug turbo kit, i read on a sight i found that the one out of a 300ZX would fit on nicely
