Topic: Yellowcar progress
 of 3 Next >>
Yellowcar
bullet Topic: Yellowcar progress
    Posted: 07 July 2004 at 8:38pm
Since I actually got my interior done and drove my car a few places (like the vintage races) I figured it was time to take it apart again.
I installed the new front suspension and brakes I bought a while ago.
Front struts off an 82 280ZX (strengthened and shortened with coil overs).
Eibach 250 LB springs
Koni adjustable road race inserts.
12” vented rotors with AP racing 4 piston calipers (like touring cars run)
Ground Control camber plates.
Bump steer spacers.
Surprisingly even with the (much) bigger calipers and rotors the new parts lightened each side 13 LBS. The new calipers are quite a bit lighter than the 280 calipers, the bigger rotor is a wash due to the hat being aluminum and the rest of the savings are in the spring and camber plate.
BTW my old 280 struts are for sale...
'72 510 LZ2.5
'06 VW Jetta
'98 mercedes C280 sport
'01 ZX9R
'02 ZX6R
bullet Posted: 07 July 2004 at 11:05pm
Looks very clean! Good job!
My 1965 L 320 {all original}
69 L 521 w/KA swap
94 Hardbody [custom]
74 620 project
bullet Posted: 07 July 2004 at 11:20pm
that's so hot.
1973 620 "Prerunner"
L20B,A87,5spd.Lynx,40dcoe,
header,cammed & bored.
zx oil pump,starter,headbolts
& water pump/pulley.
bullet Posted: 08 July 2004 at 9:43am
Wow! looks amazing and probably works very well too.... $800 later...
Yellowcar
bullet Posted: 08 July 2004 at 12:22pm
Thanks
Not sure how it works yet I am waiting for the brake lines to arrive this morning so I can drive it but I expect that I will have all the brake I need no matter what I do with the car.
The brake kit by itself goes for about $1,700 new but I bought it and the struts (but not the spring, camber plate and insert) used from a guy who ran them on his GT4 510.
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
Yellowcar
bullet Posted: 01 August 2004 at 10:35pm
I finally got the brakes finished and took the car out for a drive.
I was waiting for the brake line adaptor and finally gave up on Summit and ordered them from Pegasus racing. The new hoses worked well (kinda had to guess what ones to use) and everything fit.
Whoo hoo does the car have brakes now!! It also seems to handle a lot better. I set the Konis at about 2/3 firm and am probably running too much camber. The car steers much easier and turns in a lot faster.
Now I just need to get it aligned, install the rear shocks and maybe put rear disks on it (what is the easiest swap?)
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
Yellowcar
bullet Posted: 15 August 2004 at 12:08am
I installed the rear shocks (KYB AGX adjustables) yesterday and it is handling better now. I can't wait to get the alignment done and get an adjustable rear crossmember so I can align the rears.
I think I'm going to get a set of Panasports and some Falken Axenis sports I'm thinking of 15X7 wheels with 205-50-15s what do you think?
Tonight I FINALLY got around to installing my Electromotive ignition.
I have had the parts sitting around for a very long time and decided I needed to get it done.  I installed the ignition/coil box on the firewall and made a bracket for the crank pickup. Now i just need to wait for my new Ignition wires to come in (need HEI wires for it) and do a little more wiring and it should be running!
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
Yellowcar
bullet Posted: 19 August 2004 at 11:24pm
Got my Electromotive Ignition installed tonight.
Still need to clean up the wiring and install the ignition control inside the car (so I can adjust the timing on the fly) but it runs.
I have done no tuning yet but the car seems smoother and like I picked up a little torque.
Now I need to figure out what to do with the distributor not sure if you can just get rid of it and cover the hole because it seems like the oil pump drive might need the support..any ideas on this?
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
bullet Posted: 21 August 2004 at 8:05pm
damn, that is purty. But I have no ideas, sorry.
Yellowcar
bullet Posted: 01 September 2004 at 7:48pm
I just ordered a bunch of parts from Datsport today. They have been very nice to work with.
I ordered
Adjustable rear crossmember
Rear springs
steering box brace
rear crossmember mounts
rear control arm mounts
idler arm bushing
headliner kit
new dome light assy
I can't wait to get everything!
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
defdes
bullet Posted: 01 September 2004 at 8:23pm
That's nice, re-routing the gas like that.
I have dealt with Datsport also and liked them very much, I got all of my new rubber seals from them, was pretty happy except for the fit on the F&R windscreens, but the price was right.
'72 LZ22 510
'71 L16 510 Vintage CS Racer
Yellowcar
bullet Posted: 17 September 2004 at 12:16am
Glad to hear that, my parts are supposed to ship next week
I also ordered a rear disk kit from top end yesterday (uses wilwood calipers) I'll try to post some pics when the parts arrive.
Anybody know where to get panasports?  I talked to calssic datsun and dave turner and they are out of stock (bout 4 months out, ouch!)
Looking for 15X6.5
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
Yellowcar
bullet Posted: 09 January 2005 at 10:06pm
I installed my rear crossmember, control arms, rear disks, springs and panasports with the Falken azenis today
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
GTZilla
bullet Posted: 10 January 2005 at 1:45pm
What if anything are you going to do for a parking brake?
Edited to say, BTW nice tool organization
defdes
bullet Posted: 10 January 2005 at 3:50pm
More questions...
What size are those tires? and that rear end from Australia, is it just slotted or what?
'72 LZ22 510
Yellowcar
bullet Posted: 10 January 2005 at 5:38pm
I am going to install a hydraulic parking brake (similar to line lock) and a proportioning valve.
The tires in the background are 195-50-15 Yokohama AVS-es100s on 15X7 wheels (I am selling these)
The tires on the panasports are 205-50-15 on 15X6.
The rear crossmember is from Datsport and is slotted with an adjustment system for the bolts so it is easy to change the alignment settings but the bolts will not slip out of alignment.
The control arms are pretty standard except they are cleaned up (misc hangers removed) powder coated, have new wheel bearings and have nolatek bushings. My old arms had a slightly (.030) bent axle on the right side and worn splines so instead of buying a new axle (very expensive) I just decided to buy the rebuilt arms from Datsport, their stuff is great. I do have a set of newly painted control arms (deltron urethane paint) for sale but one side needs a new axle.
'72 510 LZ2.5
'06 VW Jetta
'01 ZX9R
'02 ZX6R
bullet Posted: 10 January 2005 at 6:39pm
What rear coils you using? brand?
I like those Panasports!!!!!
bullet Posted: 10 January 2005 at 11:01pm
Dang, that's a nice car! And those springs are Yellow! woot!
I didn't know the 510 rear suspension was like that. Its much different than the Z's strut... more like the late 70's 510.
GTZilla
bullet Posted: 11 January 2005 at 2:03pm
Bleach, the late 70's 510 had a live axle, like a pickup. The early 510's were like your ZX rear suspension.
bullet Posted: 11 January 2005 at 2:30pm
Yes, other than having 4 lugs and a red shock absorber, it looks nothing like an A10 setup. The late 510 rear axle has the coil spring directly on the axle and 2 sets of centering link barsrunning from the front of the axle to the body.
