Topic: 521 parts wanted
madizm620
bullet Topic: 521 parts wanted
    Posted: 26 June 2004 at 3:29am
new datsun to the family collection and am having a hard time finding any body parts for this beast, the only thing i need is a driver side fender cause it is rusted pretty bad at the front just above the headlight. Other then that this truck is mint no rust on frame or in floors or anywhere else except that fender, brand new hub caps and beauty rings, new datsun 1600 fender emblems, newer L20b motor, only 4 speed but i have a spare 5 speed to throw in it and it was $1000, do you guys think this was a good deal?
Lean Green Datsun Machine
madizm620
bullet Posted: 26 June 2004 at 3:39am
Oh and is there any way to squeeze a brake booster into the 521? cause the brakes sure are alot stiffer then the 620.
bullet Posted: 26 June 2004 at 2:42pm
Very clean 521! I think i still have a dr. side fender you can have for free. Just pay for shipping. I live in San diego ca.  zip code is 91910.
My 1965 L 320 {all original}
69 L 521 w/KA swap
94 Hardbody [custom]
74 620 project
madizm620
bullet Posted: 26 June 2004 at 4:40pm
Pac I will definatley get the fender if you still have it. Will a 620 5 speed fit into the 521? or is the transmision shorter?
Grahem
bullet Posted: 26 June 2004 at 5:40pm
I think it has the shorter trany like the 73 620's if its stock
btw is that the truck off the vide site?
madizm620
bullet Posted: 26 June 2004 at 5:58pm
yup it the truck from Gabriola Island
bullet Posted: 26 June 2004 at 7:28pm
The only 5-speed that's the same length and the stock 521 tranny is the '77-79 200SX/510 Dogleg (well, 80-81 510 with a bias change). But you'd still need the '73 620 front driveshaft section since the 521 uses a flange and every other Datsun tranny uses a slide sleeve.
I have heard (no confirmation) that you can use the SWB '74-79 driveshaft front section to put a '77-80 truck 5-speed in.
madizm620
bullet Posted: 26 June 2004 at 11:30pm
In a king cab and a long box which part of the drive shaft is longer? the front part or the rear? as apposed to the single cab. just wondering cause i could try the drive shaft from my long bed or my king cab to see if that would work with the 5 speed.
bullet Posted: 27 June 2004 at 12:11am
Its the front part that varies in length.
All 620 driveshafts are the same length from the carrier bearing back to the axel.
madizm620
bullet Posted: 27 June 2004 at 12:20am
ok thanx bleach thats good to know.
layinga521
bullet Posted: 27 June 2004 at 12:43am
Very Nice! Hard to believe my 521 was ever that high in the air, lol!
bullet Posted: 27 June 2004 at 10:12pm
my short 5-speed is from a 720 4X4. the bitch is 4X trannys don't have the speedo hook-up. it's on the transfer case. probly not much help for ya, but its an option anyway.
bullet Posted: 27 June 2004 at 10:32pm
It's not the same short, though. And a different output I believe.
bullet Posted: 28 June 2004 at 4:15pm
the bellhousing is clocked a little for the Z series engine so it squishes the tranny mount to one side a bit. on the plus side, the starter is mounted higher so its easier to change. the output splines are the same but, in '85 i think they went to the bigger u-joints on the driveline. the shifter is also like 6" closer to the front. other than that it looks just like the long tail 4-speed that came in my '76.
bullet Posted: 28 June 2004 at 4:52pm
http://www.up22.com/ranger.htm
Had the front fenders. But I dont know if its good quaility or not. Make take fender off and weld new metal from inside(by professional).
Lower that Truck!!!!!!!!!!!!Pathfinder wheels!
Paint the rear bumber Polish chrome,silver. Or maybe remove it and have some chick on the phone ram ya in the ass.
Great to see nice 521s still out there.
bullet Posted: 29 June 2004 at 11:41am
Madizm 620,
Ck to see if spacers under the endine mounts.
What I have been seeing is people raising the motor to keep the oil pan(521) from hitting the steering bar/arm.
Seems the L20 hangs abit lower causing it to rub.
I just want to know how much to raise it 1/4, 1/2in ? if I ever put a L20 in there.
PM me and tell me what you have!
As datsunaholic said the 521 uses a different output set up on the trans. The trans is same as a 510 5sp but the 510 uses a yoke set up. Anybody who has a 510 with a 5sp people should get it out and see hoe it was done. Cause the 521 could sure use a 5sp. A longer duration acam also!
bullet Posted: 29 June 2004 at 11:38pm
Well i just found out that i dont have the fender anymore. I think i may have tossed it when i cleaned up my yard. Sorry man!
69 L 521 w/KA swap
74 620 project
bullet Posted: 30 June 2004 at 12:03am
bullet Posted: 30 June 2004 at 12:07am
Ahh bleach, you finally saw my 70's 620 slot trock,haha! I posted a bigger pic of it under general automotive.topic-new Datsun toys.
69 L 521 w/KA swap
74 620 project
