![]() | 510 North West Datsun Enthusiasts Forum : Datsun : 510 Topic: R200 |
aojk
Novice ![]() Joined: 13 April 2004 Location: United States Posts: 24 |
![]() Posted: 12 May 2004 at 11:16pm |
Does anybody here have a good source of information on retro-fitting an R200 rear end in a 510? Which car would be the best to look at in a wrecking yard for a nice LSD, 300zx?
Go to ratdat.com in the tech section has a R200 install
remember mosr R200 are not the gear rationyou want so ck first. I think the 300zx has better ratios like you said. You really have a High powered 510? Maybe just get a Subaru R160 the early yr ones go to the Dime quarterly in the tech section gives info on LSD options. |
The 300ZX turbo LSD is a 3.7 ratio, and Hainz has that ratio in his 510. You probably want a 3.9 or 4.11 ratio but they don't come stock in LSD. If you've got a 4-cyl you don't need the limited slip. Just get a 4.11 R180 open diff
aojk
Originally posted by Hainz
Go to ratdat.com in the tech section has a R200 install remember mosr R200 are not the gear rationyou want so ck first. I think the 300zx has better ratios like you said. You really have a High powered 510? Maybe just get a Subaru R160 the early yr ones go to the Dime quarterly in the tech section gives info on LSD options. Thank you for the link! My 510 is not very powerful at the moment (L20) but I'm in the process of collecting parts for a restore and an SR swap. Mostly I've been buying rubber and whatnot thus far but I need a clear idea of where to go from here for the SR. I feel the R200 might be a good move. Actually, that's another good question... Originally posted by Bleach
The 300ZX turbo LSD is a 3.7 ratio, and Hainz has that ratio in his 510. You probably want a 3.9 or 4.11 ratio but they don't come stock in LSD. If you've got a 4-cyl you don't need the limited slip. Just get a 4.11 R180 open diff Ahh, thanks for the info, 3.7 will do just fine I think. I'm planning on making a fast car but it's also going to be for street. :) |
http://www.mckinneymotorsports.com/cars/datsun/photo/index.php
try these guys and ask them for a conversion price then Half it. Just to give a idea of what your doing. Maybe some used sidedrafts and a cam for that L20 wouldnt be that bad. I have seen to may projects that never were completed.(esp 510s) |
aojk
http://www.mckinneymotorsports.com/cars/datsun/photo/index.php try these guys and ask them for a conversion price then Half it. Just to give a idea of what your doing. Maybe some used sidedrafts and a cam for that L20 wouldnt be that bad. I have seen to may projects that never were completed.(esp 510s) Yeah, but I'm not typically that sort of person; when I get something stuck in my head it's happening. Plus I seem to have a thing with spending way more money on a car than what it's worth. I have a BMW e30 for example that I major body work done on. Actually, its front half is an '87 and the back half is a '90. Haha! I believe I already have over $1000 in body panels, rubber, and lights for my 510. ;o) |
The 1989-91 bumpers look way better. Put that on the front of your BMW 325.
aojk
The 1989-91 bumpers look way better. Put that on the front of your BMW 325. Yeah, you're correct! I have the later style rear bumper but the front ones theoretically won't line up correctly. I might get the BMP after market front bumper that converts the early models to look more like the later style. It will cost around $400 though and I'm currently tied up on my Datsun project. :) |
what about an lsd for a 620 rear? Never heard of one, myself, but I always here of this subaru conversion for the 510
aojk
Originally posted by Ryan in Seattle
what about an lsd for a 620 rear? Never heard of one, myself, but I always here of this subaru conversion for the 510 That's a good inquiry. What does the rear end of a 620 look like? |
There was a rare (probably NLA) Nismo H190 LSD. Was sold for 4X4 720s. Unfortunately the H190 was a nissan-only diff. Probably easier to find and swap out an extire axle assy from a newer (90s) truck that has it or has a cheaper aftermarket setup available.
