Topic: ZEED’S 620 project
ZEED
bullet Topic: ZEED’S 620 project
    Posted: 05 May 2004 at 10:23pm
 I've made some progress and thought I'd share some pictures.I haven't had any luck posting them (files are too large) so I thought this would be a good way to show them. I'll add to the album as I make headway and let you know when I have new pics. I have some parts for sale (SU setup,header,new 15in wheels and tires,built l20b,front hubs & calipers) if anyone is interested I can add pics of them also , well , let me know what you think.
http://photos.yahoo.com/zeed620
79 620 WITH 83 280Zx TURBO ENGINE,TRANS, INDEPENDENT REAR END,280Z 4-BOLT FRONT HUBS WITH 300ZX ROTORS & 88 TOYOTA 4X4 TRUCK CALIPERS,18INCH WHEELS, DOING BODYWORK NOW.
bullet Posted: 06 May 2004 at 2:39pm
I still don't see any pictures in your photo gallery. I'd like to see what you're doing to the L28 truck.
ZEED
bullet Posted: 06 May 2004 at 5:27pm
 Try again , it should work now
madizm620
bullet Posted: 06 May 2004 at 6:57pm
still nothing showing up
Lean Green Datsun Machine
ZEED
bullet Posted: 06 May 2004 at 8:21pm
 Sorry guys ,  I think I've got the settings right now , try it again.
bullet Posted: 06 May 2004 at 8:47pm
Hey Zeed, is that all that there is to the front brake swap? Know any good drum upgrades?
HEY SMOKINTHEM, FREE UP YOUR PRIVATE MESSENGER, WINK WINK....................
1973 620 "Prerunner"
L20B,A87,5spd.Lynx,40dcoe,
header,cammed & bored.
zx oil pump,starter,headbolts
& water pump/pulley.
ZEED
bullet Posted: 06 May 2004 at 9:28pm
 I'm running 280z front hubs , 4x4.5 bolt pattern to match the 280zx rear axle , the upgrade won't work with truck hubs , the rotors won't bolt up and the offset can't be corrected with a spacer , it's allready too far towards the inside. Don't know of any drum upgrades. When I have some time I'll see if I can come up with a caliper/rotor combo that will work with the truck hub.
madizm620
bullet Posted: 06 May 2004 at 11:35pm
It works now   Looking good mang
The620Kid
bullet Posted: 11 May 2004 at 3:28am
That is some nice work you've done I like it alot. Keep up the good work.
NOS is like a hot chic with an STD, you wanna hit it but you know the consequences
bullet Posted: 11 May 2004 at 11:41am
zeed, is your exhaust pipe really as close to the fuel cell as it looks? i love how you did the twin tips out of the license plate hole.
ZEED
bullet Posted: 11 May 2004 at 4:28pm
Yes the exhaust is near the fuel cell but there is a heat sheild between the two
